Crossmember Insulator advice requested
Old August 8th, 2012, 05:41 PM
71Convertible's Avatar
Question Crossmember Insulator advice requested
In the power train rebuild of my 71 Cutlass Supreme convertible, I've removed the transmission support crossmember. It didn't have insulators where it attaches to the frame rails. The crossmember was bolted directly to the frame rails. The '71 AIM doen't show that the original assembly included insulators, however I see that insulators are available, so I'd like to ask for advice from those who may have experience with them. Does this affect the alignment of the transmission and drivesaft? If added, I'm guessing that different bolts will be needed. Any experience or opinion is welcome.
Thanks,
Don
71Convertible
71Convertible is offline
Old August 8th, 2012, 06:00 PM
Run to Rund's Avatar
Bolt it directly per OEM.
Run to Rund is offline
Old August 8th, 2012, 09:53 PM
Just the facts...
BILL DEMMER's Avatar
X2
bill
BILL DEMMER is offline
Old August 9th, 2012, 09:02 AM
Your Advice
Thank you, that is what I will do.
Don
71Convertible
Old August 9th, 2012, 10:47 AM
442_1972's Avatar
Pontiac and Buick used the insulators, but Olds and Chevy did not. I'm not sure why there was a difference between the manufacturers, but that's what I've seen. The ends of the crossmembers that have insulators are slightly different than the ends of the crossmembers that bolt directly to the frame.
442_1972 is offline
Tedd Thompson
May 1st, 2013 09:11 PM
81 regency
April 10th, 2011 05:15 PM
oldsca
August 16th, 2010 04:50 PM
scott_442
May 16th, 2009 08:55 PM
chip888
July 29th, 2008 06:16 PM
Quick Reply: Crossmember Insulator advice requested
