Wrong shift cable bracket
Old Mar 5, 2016 | 03:54 AM
cecilsclassics's Avatar
Guys, I bought a new shifter cable and apparently have a 350 turbo cable bracket. I have a turbo 400. I can only line up 1 hole on the tranny pan. My question is, Can I modify the bracket mount location, by modifying how it mounts to the pan and solve the cable issue? The cable said 350/400 trannys. I am able to modify the bracket, just want to make sure if I secure the bracket so that there is no slack it would be ok. Right now, I m about 1/2" off of where it needs to be. I want to move the u slot for the cable back 1/2" and re weld it, also modify the mount, so it will fit 2 holes... Help...
Old Mar 5, 2016 | 04:10 AM
rob1960's Avatar
I'd just buy the correct bracket for the 400 trans. They're easily available from Fusick,Inline,etc & they're only around $20. If the spacing isn't correct at the trans you could have problems(it might go into park but not 1st,etc)as there's not allot of adjustment at the trans shift lever.
Old Mar 5, 2016 | 06:14 AM
^^^This. Everyone sells these. Don't waste your time with a mickey mouse solution.
rootney
Jun 27, 2014 11:30 AM
72 Olds Project
Oct 18, 2013 12:48 PM
dmberendsen
Apr 10, 2013 03:18 PM
scubastever
Oct 27, 2010 08:57 AM
ctrain22
Sep 7, 2009 10:54 AM
