TURBO 400 TRANSMISSION HOUSING
Old Sep 15, 2007 | 12:27 PM
W30MAN's Avatar
CAN SOMEONE TELL ME WHAT COMPANY SELLS A REPLACEMENT TURBO 400 TRANS HOUSING OR CASE, FOR A 1970 442 W30 (OW TRANSMISSION)? THANKS, PHIL
Old Sep 15, 2007 | 02:15 PM
I don't know if there are any companies that sell automatic transmission housings. I would think you could get one at a junkyard though. Then all you would have to do is take the innards out of it. Just make sure you get a TH 400 with a BOP bellhousing on it.
Old Sep 15, 2007 | 06:59 PM
All TH400 BOP cases are essentially the same. Some of the mid-60s Olds full size cars did not have the speedo drive provision since the cable was on a front wheel, but just avoid those. Just extract your OW tag and put it on the replacement case. Also, locate the CAPS LOCK button on your keyboard.
matviar
Feb 26, 2012 11:05 AM
80_cutlass
Mar 17, 2011 06:03 PM
Liegekiller
15
Jun 27, 2009 07:58 PM
Liegekiller
May 30, 2009 05:31 PM
