Transmission swap
Old Mar 5, 2016 | 11:49 AM
Northern Custom Cruiser's Avatar
Gearhead in training
Transmission swap
Would a trans from a 1987 custom cruiser work in a 1984 olds 98? I am very new to olds and working on cars in general so if this is an obvious answer please consider these facts and dont nail me to a cross haha
Thanks in advance!
Old Mar 5, 2016 | 02:26 PM
Thanks in advance!
The trans in the 84 SHOULD be a 200-4R. The trans in the 87 is definitely a 200-4R. They should swap with no issues, but verify that the trans pans are the same.
Old Mar 5, 2016 | 05:28 PM
Guy says its a THM 400-4R. Will that work correctly?
Old Mar 6, 2016 | 04:23 AM
"Guy" is wrong. There is no such trans. It's either a TH400 three speed or a 200-4R four speed. GM did not install TH400s in cars in the 1980s, so if it really is a TH400 it was not put there by the factory. That means we don't know which tailhousing length it has.
Again, take look at the trans pans to ID the transmission.
Old Mar 6, 2016 | 07:02 AM
Awesome thank you joe, i dont think hes quite as informed as id wish he was so i figured id consult the experts haha. He said its a 4 speed with overdrive. Im assuming that would be the 200-4R you mentioned above?
Old Mar 6, 2016 | 07:13 AM
The 200-4R is the only overdrive trans Olds ever used behind the 307 in a RWD application.
Old Mar 6, 2016 | 07:32 AM
Thank you much joe! You never fail me haha
bccsrc
Feb 6, 2012 07:05 AM
Big Todd
Nov 2, 2010 12:24 PM
slodat
Aug 20, 2010 10:01 AM
jamestina
Apr 8, 2010 01:27 PM
1980oldscuttnewbie
Apr 30, 2007 05:22 AM
