Transmission noise - help!
Old Sep 15, 2017 | 08:33 PM
Bluedane's Avatar
I need some troubleshooting with what i think is a shifting problem., here's my specs and problem
72 Cutlass S with 455
Rebuilt 350T transmission with shift kit
370 (I think) gears, eaton posi
10 bolt rear end, I think original
Hurst 3 speed floor slap shifter
Trans fluid level is good
New u joints
I have a very loud "clunk" that even shakes the car... it feels like someone ran into me. it only happens in drive, at low speeds, when it upshifts into next gear. if i take off in 1st or 2nd and then shift into drive its fine.
Thanks for your feedback!
Old Sep 16, 2017 | 09:51 AM
Firewalker's Avatar
New u joints
I had a TH400 behind my 461 that did the same thing, at times, and it is very annoying. The trans was fine and had a shift kit in it and thats just the way it acted at times, at very low speed like a few miles an hour going over a speed bump for example.
delta_88_germany
Jan 11, 2015 01:34 AM
My62F85
Jul 31, 2014 09:44 AM
Rocket331
Aug 17, 2012 03:12 PM
JTrujillo
Jul 30, 2010 09:50 AM
sully
Brakes/Hydraulic Systems
Mar 30, 2007 11:26 AM
