transmission lines
Old Jul 9, 2014 | 10:42 AM
datdudelu's Avatar
transmission lines
I'm having a problem with my transmission lines. Well I have 86 cutlass had a Chevy 305 taken out so I could go with the Chevy 350 with a TH400 tranny now the my problem is the transmission lines how are they connected to the radiator is it top to bottom or top to top could somebody help me please?
Old Jul 9, 2014 | 10:48 AM
Fluid flows out of the bottom connection of the trans, then to the lower connection of the radiator and out through the top to the top of the trans.
Old Jul 9, 2014 | 10:50 AM
datdudelu's Avatar
Ok thanks for help now I can go get back under the car n maybe finish it today
Old Jul 9, 2014 | 11:22 AM
Professur's Avatar
Blow out the lines before you hook them back up if they've been open any length of time. All manner of things will crawl in there when your back is turned.
Old Jul 9, 2014 | 11:56 AM
Arrowstorm's Avatar
Olds Wagonmaster
Definitely blow those lines with transmission line cleaner!!!
Old Jul 24, 2014 | 10:54 PM
johnnyjaws's Avatar
Or a good old air pressure will work
dallasite21
Sep 29, 2010 03:32 PM
misercola
18
May 3, 2010 03:39 AM
erke88
Apr 19, 2010 11:51 PM
1973olds98
Mar 29, 2010 05:36 PM
CUT-N-UP
Mar 17, 2010 12:40 PM
