350 Rocket Transmission Cooler lines
Old Sep 29, 2010 | 05:57 AM
dallasite21's Avatar
I am having the damndest time trying to figure out where the two lines coming from the transmission cooler go. I dont remeber where I disconnected them from and I dont see any where tha they would connect.Here is a pic. Does anybody know where they go?
Old Sep 29, 2010 | 06:11 AM
72 cutlass455's Avatar
Thats a charcoal canister part of a early emission system
Old Sep 29, 2010 | 06:27 AM
Well the two lines Im talking about are coming from behind the radiator. I am aware of the charcoal canister and the lines that run to it are much smaller than these two lines. I dont think they go to the canister. I could be wrong but I dont think so.
Old Sep 29, 2010 | 07:30 AM
There will be fittings on the transmission it self to run the lines on mine i just use the cooler on the radiator. Is this a after market cooler ? Used one on a auto trans tow vehicle years ago.
Old Sep 29, 2010 | 11:29 AM
OK.. That makes since. I bet those lines were already capped off. I will just leave them alone. Thanks alot.
Old Sep 29, 2010 | 12:08 PM
Lady72nRob71's Avatar
If there IS an aftermarket cooler in front of the radiator connected to those hoses, I bet they were once connected to the two metal tranny coolor lines that are screwed into the radiator.
Old Sep 29, 2010 | 03:32 PM
Bluevista's Avatar
Registered
The transmission fluid should go through the radiator cooler then through the auxiliary cooler and back to the trans. The one line looks short?, maybe it bypassed the radiator cooler?
There should be a male thread barbed hose fitting for the radiator to hook up the rubber line from the radiator to the cooler and a female barbed fitting for the end of the hard trans return line fitting for the other hose. I would hook it up if it's already there, sure can't hurt, unless you're going for a stock resto look that is.
Kid Thunder
Jun 4, 2015 11:14 PM
Stevec
Feb 3, 2015 03:06 PM
Mark71
Sep 9, 2011 06:03 PM
70Cutlass_408
May 1, 2011 08:57 PM
bjtstarfire
Dec 13, 2008 08:48 PM
