Trans Temp Sending Unit
Old Oct 4, 2018 | 09:38 PM
pettrix's Avatar
Where is the best spot to install the trans temp sending unit?
  1. Trans pan
  2. Cooler Line - Out
  3. Cooler Line - Return
Old Oct 4, 2018 | 11:56 PM
The pan is probably the best place to put it, it will give you a average temp. The cooler line that goes to the radiator will tell you the temp of the oil coming out of the converter, it’s always going to be much hotter than anyplace else.
Old Oct 5, 2018 | 10:00 AM
11971four4two's Avatar
MOTORHEAD
Here is what B&M recommends..............
STEP 2.Locate the oil return line to the transmission. OnChrysler and most Ford transmissions, this is the line to therear of the transmission case. On GM TH-350, TH-400, TH-700R4, and Powerglide transmissions, this is the upper oilline to the transmission case. On GM TH-200, TH-200R4,4L80E and Ford AOD transmissions, this is the lower oil lineto the transmission case.Note: This location is recom-mended to monitor the true transmission temperaturegoing in, as well as checking the oil cooler efficiency.
Old Oct 5, 2018 | 12:28 PM
pettrix's Avatar
Does the cooler return line then just dump the trans fluid into the trans pan?
If so, then the return line location should show the same temperature as the fluid in the pan, correct?
Old Oct 5, 2018 | 01:04 PM
MOTORHEAD
Hey , I put the temp sender in the return line as manufacturer recommended. It worked fine. I am not sure why you would want to put a hole and a sending unit in the transmission pan....
Old Oct 5, 2018 | 08:00 PM
most transmissions use returned converter oil as lube oil for the bushing and planetary gear sets.
Old Oct 5, 2018 | 08:02 PM
it gives you the most accurate AVERAGE temp reading. As far as I know, every transmission manufacturer that uses a temp sensor has it inside the pan, usually on the valve body.
pmathews
15
Sep 21, 2020 04:14 AM
304forest
Jan 28, 2015 11:19 AM
getawaycar
Sep 30, 2012 06:36 PM
84hurst
Jul 16, 2012 07:56 AM
Mark71
Oct 4, 2011 02:43 AM
