Trans line fitting..
Old Dec 3, 2024 | 05:36 PM
Tancuda's Avatar
Hi everybody, if I want to bend my own trans cooler line (TH400), which fitting do I need ?
I think 1/2-20 on the trans side but on the radiator the spec is 5/16 inverted flare...which fitting would it be ?
Old Dec 4, 2024 | 01:57 PM
They are 5/16 tubing. Last time I made my own I used 60 inch long lines and had to cut and flare for a perfect fit.
Old Dec 4, 2024 | 02:14 PM
Tancuda's Avatar
Thanks for the replie.
Are they the same style at both end as in the picture below ?
Old Dec 4, 2024 | 04:30 PM
Loaded68W34's Avatar
Yes, they are inverted flare at the radiator and the trans.
Old Dec 4, 2024 | 04:41 PM
Tancuda's Avatar
Thanks for your help
Old Dec 4, 2024 | 06:25 PM
bccan's Avatar
IF you want to do it more like factory did, they have, at least at times, used a “long” tubing nut at the transmission end of the line. Still the same wrench size but hex is appx 3 times “taller,” I would assume to make it easier to wrench on in the tunnel confines. More of a luxury than necessity and if bending your own lines they may present a problem to get a tight bend and enough tube to flare but they’re kind of nice.
Found it-
https://www.inlinetube.com/products/tn16
5/16" is the size of the tubing. The inverted flare nuts that fit that diameter tube are 1/2-20 thread. Note that the the adapter fittings that screw into the aluminum trans case have male straight thread that seals with a crush washer and female 1/2-20 inverted flare threads that the tube nuts thread into.
Old Dec 4, 2024 | 06:51 PM
Tancuda's Avatar
Found it-
Ho !! That is exactly what I have at the trans end of the line, didn't know it was stock...good info thanks
Old Dec 4, 2024 | 06:57 PM
Tancuda's Avatar
Yes, I can see those nuts on the trans, and I suppose the washer is only good for just one tightening ? thanks for the info Joe
Old Dec 5, 2024 | 02:16 PM
I wouldn’t be surprised to learn that technically the copper sealing washers are supposed to be one time use. In the real world, as long as they are in good condition with clean sealing surfaces I have never had problems with them leaking.
Don’t use pipe thread fittings in the case. More times than not the case will crack.
If you decide to use the factory long style flare nuts, be sure to pack the inside of the nut with antiseize. Those long nuts have much more room to fill up with crud, and are more difficult to break loose from the steel line once the environmental loctite sets in.
Old Dec 5, 2024 | 03:51 PM
Tancuda's Avatar
Good advice thanks !
Prodjbm
Feb 6, 2022 10:40 AM
JackJack56Olds
Dec 30, 2015 07:05 PM
Macadoo
Jun 22, 2014 09:04 PM
getawaycar
Sep 30, 2012 06:36 PM
68conv455
Jan 3, 2009 11:53 AM
