trans fluid level
Old Oct 21, 2010 | 02:03 PM
1973olds98's Avatar
trans fluid level
Ok,,,I finally got my rebuilt 455 started,,,,I still have the car up on jack stands and was shifting the transmission and the wheel started turning but then stopped...I checked the fluid level and it was barely on the dipstick...I added another quart and the wheels started to spin again but then stopped...So far i added a 5 quarts total of tranny fluid ...Now in the book it states for a complete tare down it takes 10 quarts...Now i didnt do a complete tare down just drop the pan,,changed the filter,,,Pulled the pump and changed the seal along with the rear seal, and the cooling lines,,,,Do I just keep adding untill it reaches the full mark...
Old Oct 21, 2010 | 02:09 PM
Just keep going. 1/2 quart at a time. With the car level.
The level on the stick will stay at the very bottom, looking like you need about a quart and a half, then suddenly it will be overfull (unless you go 1/2 at a time).
You're filling up the converter, which must have had some poured out of it.
Old Oct 21, 2010 | 02:16 PM
1973olds98's Avatar
ok will do,,,thanks
Old Oct 24, 2010 | 10:50 AM
1973olds98's Avatar
dang it took 8.5 quarts to fill...it did go allittle pass hot full mark,,,will this be ok,,,,i would say i added 1 pint to much
Old Oct 24, 2010 | 02:33 PM
Originally Posted by 1973olds98
... i added 1 pint to much
What'd I tell ya?
As it keeps going in, you start getting careless and adding more at a time, then it suddenly creeps up on you and it's overfull...
It's always better not to over fill an automatic transmission.
If it's just a tiny bit over, that's okay.
If it's more than that, you should use an oil gun (like you use to fill the rear end with gear oil) and a long, clean hose to pull out a bit through the dipstick tube.
Takes about 2 minutes.
$11.00 at Advance Auto and others.
Congaratulations of getting it going. How's it run?
Old Oct 24, 2010 | 04:37 PM
1973olds98's Avatar
I just took it for a spin and checked the dipstick,,Its pretty much dead on the full hot dot. WHen i get it out again I will check again,,,,If it shows to much i will pump the extra out...How does she run?,,,Right now there is no exhaust ,,It running straight out of the headers..Its loud,,I am going to the muffler shop this Friday to get duals ran out the back with a couple chery bombs...
Old Oct 24, 2010 | 06:42 PM
455 + No Exhaust Past Headers = LOUD
rcdynamic88
Brakes/Hydraulic Systems
Aug 14, 2014 06:00 PM
poorboy_616
Jul 4, 2009 05:16 PM
cfair
Jun 8, 2009 12:37 AM
asadebo
Alero
May 3, 2009 08:35 PM
The_Jeremiah
May 2, 2008 05:22 PM
