Tranny Temp Sensor
Old Jul 23, 2012 | 11:34 AM
censley's Avatar
Tranny Temp Sensor
Does anyone have a tranny temp senor in their set up? I need to invest in one and would like to know which type/kind/brand to get.
It's for a 700R4
Thanks!
Old Jul 23, 2012 | 05:50 PM
Redog's Avatar
If you're thinking about an aftermarket gauge set-up there are 2 options.
One is a splice of a "T" fitting in the top line going to the raditior, the other is to weld a bung in the pan itself.
I'm probabky going with the bung route
Old Jul 23, 2012 | 07:23 PM
Qwik71442's Avatar
Full-time Taxpayer
It's for a 700R4
Thanks!
I used the Auto Meter 3357. I put the sensor into a bung on the side of my 2004r pan. Had the pan made with two bungs one for a drain the other for the sensor....
Old Jul 23, 2012 | 09:13 PM
Redog's Avatar
Do you have dual exhaust? Have you had any problem with the tip on the sensor (wiring) getting wet?
They are my only 2 concerns.
Working on putting in Sunpro "Faze" gauges in my Delta to replace the factory gagues that are all wrong I know they are rice, but they are in my closet taking up space and BRAND NEW they are going for $20 on eBay. I did need a water temp gauge, but for $25 shipped to my door and I'll have oil, volts, tranny temp, and water temp, I'll take it
84hurst
Jul 16, 2012 07:56 AM
54oldz
Jun 20, 2012 07:13 PM
scott_442
Feb 22, 2011 05:26 AM
Aceshigh
Oct 1, 2010 10:35 AM
cormike
Aurora
Jan 4, 2009 07:30 AM
