tranny cooler
A good place to pick up a cheap transmission cooler is any wrecking yard with a lot of mid 80's Chrysler Mini-Vans. The long wheelbase turbo versions used a good sized tranny cooler that mounted in front of the radiator.
I am no help in how to hook it up, but if you need a quick and cheap source for a cooler that is what I always use. I also grab the hoses but only so I make sure to get new ones that fit the cooler.
I would not reuse cooler lines that are 25 years old.
![Wink](https://classicoldsmobile.com/forums/images/smilies/wink.gif)
