tranny cooler ques
Old Oct 26, 2010 | 08:57 AM
ELECMAN's Avatar
tranny cooler ques
I wanted to install a tranny cooler in my 72 cutlass 455ci motor and a th400 tranny I do alot of manual shifting have a dual gate shiter.I see a lot of tranny coolers have btu not sure what that means but I bought the factory aux tranny lines for that year the factory one is to expensive.what is a good tranny cooler on the market and how many btu do i need thanks
Old Oct 26, 2010 | 12:24 PM
Rickman48's Avatar
A cooler is only mandatory if you've a higher stall convertor that'll generate heat!
Unless you're downshifting from 4500, [which'll blow the front pump] I'd not worry about it.
A shift kit and changing all the fliud to B+M Trick Shift would help more!
Old Oct 26, 2010 | 06:45 PM
Bobsw32's Avatar
BobsW32
I use the "manifold" style verses the "Snake" style and also get it with "AN fittings verses a barbed hose connection...Probably over kill as the others have been around for years.......
Old Oct 26, 2010 | 09:29 PM
ELECMAN's Avatar
with the manual shifting when should you shift in to second then third at how many rpm
Old Oct 27, 2010 | 04:43 AM
67w30's Avatar
Whats the difference between 'Manifold' Style and 'Snake' Style? I have never heard a transmission cooler described like this.
k3
Stevec
May 26, 2014 07:18 AM
ELECMAN
Jul 18, 2011 03:00 AM
jugdish
May 15, 2011 06:42 PM
ELECMAN
Aug 17, 2010 07:13 PM
rzr09
Apr 1, 2009 06:36 PM
