custom making a aux tranny cooler
Old Aug 17, 2010 | 02:54 PM
ELECMAN's Avatar
I ordered the original aux lines to the auxilary tranny off line.I was going to enter the line coming from the tranny into the top of the radiator,the bottom of the radiator line into the aux cooler and the other side of the aux cooler to the tranny.do they make a coupling to join the two lines together.If so what side is the actually nut size and tubing size thanks.
Old Aug 17, 2010 | 04:12 PM
TripDeuces's Avatar
Most tranny lines are 5/16 just like some brake line. The make 5/16 tubing nut connectors for joining lengths together. Any auto parts place will have them.
Old Aug 17, 2010 | 07:13 PM
Be aware that if you are using factory style flare nuts, you need a coupler for inverted flare fittings. A normal pipe thread coupler will not seal.
Sampson
Jan 13, 2014 07:36 AM
jugdish
May 15, 2011 06:42 PM
84oldsDelta88
Mar 30, 2011 09:16 PM
ELECMAN
Oct 27, 2010 04:43 AM
rzr09
Apr 1, 2009 06:36 PM
