TH400 Oil Seal
Old Aug 22, 2012 | 04:59 PM
Delmont 88 PA's Avatar
TH400 Oil Seal
Does anyone know where you can buy individual internal seals for a TH400? It is a steel oil seal that goes on the input shaft and into the oil pump. It's approximately 1-1/8" in diameter and locks.
The attached picture shows what is left of the original.
Thanks!
Old Aug 22, 2012 | 07:16 PM
You can order individual seals and gaskets thru TransStar. Find a transmission repair shop and ask to look thru the catalog. I'm very familiar with the TH400 trans, they don't have a sealing ring on the input shaft. I haven't had a switch pitch trans apart in a long time, I'm pretty sure those don't use rings on the shaft either. Are you sure this in a TH400 trans?
Old Aug 22, 2012 | 07:34 PM
BILL DEMMER's Avatar
Just the facts...
any decent tranny shop should stock one. you could also try napa.
bill
Old Aug 23, 2012 | 04:57 PM
TH400 Trans Pics
The trans is a TH400. I noticed in the factory shop manual that this shaft oil seal ring is listed for 1965 to 1967 only. Newer TH400's probably don't have it.
One picture is to show that this is a TH400 and the other is to show where the shaft oil seal ring (8623296) is located--at the tip of the screwdriver where the pump enters the forward clutch.
Thanks for responding!
Old Aug 23, 2012 | 06:23 PM
Hmm, guess I haven't had one apart that is that old. Learn something new every day!
I would guess the sealing ring has something to do with the switch pitch. Head to your nearest trans shop with the old seal in hand and ask to go thru the spare parts pile (every trans guy has one!) and see if you can find a match.
Old Aug 24, 2012 | 07:10 AM
Likely due to the switch-pitch converter on the 65-67 transmissions.
Old Aug 25, 2012 | 02:45 PM
Thanks and I'm learning a whole lot.... So I'm guessing if I get another input shaft and converter (one with a slightly higher stall) this problem will go away?
Old Aug 26, 2012 | 04:23 PM
Found the ATP part number (JR58) and did a search. Purchased 2 from Amazon.
Amazon for a hard to find item like this! Go figure....
Old Sep 26, 2012 | 05:17 PM
The seals (got 2 in case I break another) have arrived from Amazon.
What is a switch pitch convertor?
Old Sep 26, 2012 | 06:27 PM
It a converter that can electrically change the stator angle inside the converter to offer 2 stall speeds. Buick, Olds and Cadillac were the only car lines to use it. There is a switch mounted somewhere on the throttle linkage that engages the higher stall speed above 60% throttle opening. I heard it was discontinued due to cost and because the converter has a weird "whirring" noise. I have a friend with a 66 442, I don't notice any noise when driving it so I cant verify the noise.
Old Sep 27, 2012 | 05:05 PM
Thanks Matt69olds. That would explain the solenoid on the oil pump!
orsogrigio
Apr 20, 2014 05:10 PM
ctrain22
Sep 5, 2009 06:25 AM
Flye
Jul 5, 2009 11:03 AM
Sixoh
Aug 8, 2006 05:11 AM
