TH350 Speedometer Gear "0" Ring Source?
Old May 21, 2015 | 09:06 AM
ddd777's Avatar
For some odd reason my speedometer gear "0" ring is missing, hence a bunch of oil leaking out.
Anybody have a source?
The kind folks at Fusick suggested I try a marine store, as they have tons of those kinds of things (I live near plenty - so that is not a problem) but I have not been able to figure out the size I should be looking for (don't have a lift at home to get under and measure)
For a 72 Cutlass
Old May 21, 2015 | 11:32 AM
Type TH350 speedometer housing seal into Google. You'll find MANY vendors who sell the inner and outer seals.
Old May 21, 2015 | 07:58 PM
coppercutlass's Avatar
Chevy budget Olds powered
Transtar industries is the first supplier that comes to mind as they have a warehouse locally and I can pick my stuff up there. They ship anywhere and their prices are fair and competitive with most ebay prices. I also may have the seals you need as I have a surplus of seals and all that stuff.
Old May 22, 2015 | 05:47 AM
ddd777's Avatar
thank you - sometimes you just gotta know what to call it for search terms.
so one of these?
Old May 22, 2015 | 06:14 AM
brown7373's Avatar
I bought speedo gears to correct speedometer error as well as O-ring and driven gear seal from PATC Transmissions, 2134A East Texas Street, Bossier, LA 7111. 888-877-1008 or 888-201-2066. This was after reading an article in one of the magazines on correcting speedometer error.
Old May 22, 2015 | 06:26 AM
ddd777's Avatar
Pretty sure I got my driven gear from PATC (http://www.transmissioncenter.org) and I got the speedo cable from Fusick - both in the last 2 years - so everything in that area is fresh.
Had somebody else (who has a lift) put them in for me, so I am not sure where or what went wrong. Just trying to correct the leak....and I think I am barking up the right tree....just want to be sure I am not buying useless parts (even if they are pretty inexpensive)
Old May 22, 2015 | 07:43 AM
so one of these?
Yes, but you can buy the seals without the housing. There was a set for $4.95 on ebay.
Old May 24, 2015 | 12:52 PM
Head to your nearest transmission repair shop. They probably have hundreds. Most 4x4 transmissions have the speedo cable on the transfer case, making the o-ring for the speedo housing in the trans unused.
oldspackrat
Aug 10, 2014 10:03 PM
costpenn
May 10, 2013 06:11 AM
fabcraft
Nov 12, 2011 11:15 PM
idaholc
Apr 13, 2009 01:33 PM
