TH 400 tailshaft swap
I have 2-3 long shaft t400 if you want I will trade out the correct parts to go the longer shaft.......
Its not to bad of swap for your transmission rebuilder,Its all apart anyways.....Tail shaft,Inner drive shaft and a few seals and such.....
Step 2: Reassemble trans with shorter output shaft and tailhousing.
Unfortunately the output shaft is the last part out of the case and the first one back in.
I have two TH-400's one short tail and one long tail. I just purchased the rebuilt short shaft and I was wanting to use the long shaft from my previous transmission, but I see thats out of the question now because another rebuild is out of the budget
![Mad](https://classicoldsmobile.com/forums/images/smilies/mad.gif)
84oldsDelta88
April 22nd, 2009 07:18 PM
jeffs 89 cutlass salon
October 19th, 2007 08:42 AM
