TH 400 tailshaft swap
Old May 16, 2010 | 08:30 AM
drec02's Avatar
What all has to be done to switch out the tailshaft of a TH-400 from a short shaft to a longer one?
Old May 16, 2010 | 12:48 PM
BIGJERR's Avatar
I bleed Oldsmobile
I have 2-3 long shaft t400 if you want I will trade out the correct parts to go the longer shaft.......
Its not to bad of swap for your transmission rebuilder,Its all apart anyways.....Tail shaft,Inner drive shaft and a few seals and such.....
Old May 16, 2010 | 07:42 PM
Step 1: Completely disassemble trans
Step 2: Reassemble trans with shorter output shaft and tailhousing.
Unfortunately the output shaft is the last part out of the case and the first one back in.
Old May 17, 2010 | 07:16 AM
drec02's Avatar
I have two TH-400's one short tail and one long tail. I just purchased the rebuilt short shaft and I was wanting to use the long shaft from my previous transmission, but I see thats out of the question now because another rebuild is out of the budget
Olds luvr
Oct 25, 2018 09:14 AM
j_link
Jun 7, 2012 08:13 AM
J-(Chicago)
Jun 26, 2009 12:52 PM
84oldsDelta88
Apr 22, 2009 07:18 PM
jeffs 89 cutlass salon
Oct 19, 2007 08:42 AM
