SHift kit install time
Old September 16th, 2012, 01:25 AM
louie's Avatar
Basic rv b&m kit. How long does it take with the tranny out?
Also if the front seal behind the torque converter isn't leaking, I've heard I should still replace it as preventative maintenance?
louie is offline
Old September 16th, 2012, 07:23 AM
If you have never done a shift kit, figure a few hours to install. Before you start, make sure you have lots of trans fluid on hand, a new filter, and a small jar of Vaseline to hold the gaskets and check ***** in place. Raise the car as high as possible, and if your trans pan doesn't have a drain plug now would be the time to add one. If you decide to add a drain plug, place a drain pan under the trans and drill the drain plug hole in the pan. No mess that way.
matt69olds is offline
truerollers
February 28th, 2017 01:00 PM
tannerblackart
August 11th, 2014 06:41 AM
zach_attack
April 25th, 2014 04:27 AM
Slater442
November 23rd, 2012 11:29 PM
rgass
February 19th, 2011 08:13 PM
Quick Reply: SHift kit install time
