SHift kit install time
Old Sep 16, 2012 | 01:25 AM
louie's Avatar
Basic rv b&m kit. How long does it take with the tranny out?
Also if the front seal behind the torque converter isn't leaking, I've heard I should still replace it as preventative maintenance?
Old Sep 16, 2012 | 07:23 AM
If you have never done a shift kit, figure a few hours to install. Before you start, make sure you have lots of trans fluid on hand, a new filter, and a small jar of Vaseline to hold the gaskets and check ***** in place. Raise the car as high as possible, and if your trans pan doesn't have a drain plug now would be the time to add one. If you decide to add a drain plug, place a drain pan under the trans and drill the drain plug hole in the pan. No mess that way.
truerollers
Feb 28, 2017 01:00 PM
tannerblackart
Aug 11, 2014 06:41 AM
zach_attack
Apr 25, 2014 04:27 AM
Slater442
Nov 23, 2012 11:29 PM
rgass
Feb 19, 2011 08:13 PM
