Sealant for trans gasket
Old Aug 22, 2015 | 08:57 AM
Bfg's Avatar
Bfg
Any adhesive or sealant on the pan gasket on the turbo 350?
Old Aug 22, 2015 | 10:23 AM
There is nothing required. The biggest issue is don't overtighten the fasteners and distort the pan rail. This probably causes more leaks than anything. I sometimes use a little high-tack to hold the gasket in place on the pan, but this can be a real pain when it's time to remove it. The other trick is to tie the gasket to the pan using thread through a few of the bolt holes. The thread is small enough that it doesn't affect sealing and there's no adhesive to scrape off the next time.
dephconn24
May 19, 2012 07:42 AM
costpenn
Body work
Apr 3, 2012 10:27 AM
boondocker
Aug 3, 2011 08:53 AM
ss0my69
Jun 14, 2011 03:17 PM
dallasite21
Jun 20, 2010 05:37 AM
