Replacement for 2 speed trans
Old Mar 11, 2013 | 03:06 AM
1966Oldsmobile's Avatar
I know that this is the small block forum but I´ve already started the thread. When the engine is removed I want to change my 2-speed transmission. Is there a "plug and play" transmission out there in 3-speed or better 4-speed. A Transmission I dont have to change anything?
Old Mar 11, 2013 | 08:50 AM
And now it's no longer the small block forum. The TH350 is as close to a bolt-in replacement for the Jetaway as you will find. The 200-4R requires a little more work. This has been covered many, many times.
https://classicoldsmobile.com/forums...-requires.html
https://classicoldsmobile.com/forums...questions.html
https://classicoldsmobile.com/forums...350-200r4.html
https://classicoldsmobile.com/forums...bro-400-a.html
https://classicoldsmobile.com/forums...t-bracket.html
https://classicoldsmobile.com/forums...t-new-one.html
BlueLouToo
Non-Olds Engines
Aug 26, 2014 04:24 AM
Jon@jonhalllaw.com
Apr 12, 2014 05:26 PM
joynerz
Jul 25, 2012 07:34 AM
Flye
Apr 18, 2011 04:24 PM
64Super88
May 15, 2010 07:24 AM
