Rebuilding Olds Turbo 350
Old December 3rd, 2018, 09:46 PM
oldscutlass74's Avatar
Can anyone suggest good racing rebuild kits for olds turbo 350? My tranny is shot, hit the wall and it won’t go into any forward gear, only reverse, it is an inside problem, the shifter cable is fine. I race a 74 cutlass supreme at a 1/4 asphalt oval, top speed 55mph, run in low gear the whole time. Looking to rebuild the tranny to compete at this track, thanks!
oldscutlass74 is offline
Old December 4th, 2018, 02:41 AM
If this is a low gear application only, any overhaul kit would work. Just make sure the forward and low/reverse clutch count is 5 clutches, 5 steel plates. You may need to machine the pistons to fit that many plates, especially if your trans came from a 6 cylinder car. Add extra bushings to the drive shell, make sure to drill and deburr the oil lube holes. Install the wide bushing in the direct clutch drum. And to ensure the trans stays in low gear, you will need to remove the sping in the low gear valvetrain, and replace the spring with a solid sleeve. The TransGo shift kit has that sleeve, and the needed parts to convert the trans to full manual. But there are cheaper/easier ways to accomplish the same thing
matt69olds is offline
Old December 4th, 2018, 05:08 AM
Just updated my post, forgot one small thing...tranny is broke lol, won’t go into forward gear only reverse
Old December 4th, 2018, 12:35 PM
Most likely smoked forward clutches. Another thing to consider adding is a low/roller (some people call it a center support) from a 700r4 trans. The rollers are a little bigger, and stronger
71OldsCut
95
May 20th, 2019 06:07 PM
Check6
May 5th, 2014 06:38 AM
OldsManNJ
November 22nd, 2012 07:48 AM
joealexander1234
22
October 14th, 2010 09:13 AM
mrveezi
February 15th, 2009 04:58 PM
Quick Reply: Rebuilding Olds Turbo 350
