Proper use of the Hurst Dual Gate Shifter
Old Jul 5, 2008 | 09:24 PM
Scotty B's Avatar
What is the "correct" way to use the Hurst DGS? The previous owner didn't use it any and couldn't provide much help. In "normal" I have D, 2 and 1. D will shift automatically, and 2 and 1 just let me drive in first or second gear. So then what are the dual gate gears for? I also have a 1, 2 and 3 on that side. If I drop it in 1 on the DG side, romp on it, then upshift to 2 and 3...whats the difference between that and doing it on the "normal" side?
Today I romped on it in 2 on the dual gate side, then shifted to 3 by shoving the shifter all the way forward...and it went into neutral...at high RPM, which, uh, really impressed the wife.
It's a 1972 442 455/TH400.
Old Jul 6, 2008 | 05:34 AM
don71's Avatar
same but different
The dual gates allow you NOT go into reverse. It should stop in the gear you select after slapping it. Perhaps your stops are worn, it should'nt go into nuetral like you describe.
Anyways, its often called a "his and hers" too. Allows for you to be more spirited in your driving on "his" side.
Old Jul 6, 2008 | 07:17 AM
The dual gate is intended to allow you to upshift while drag racing while ensuring that the 1-2 shift will only go into second and the 2-3 shift will only go into third. If you hit neutral, you shift linkage is not adjusted properly.
You start with the lever in the RH gate and all the way back. Launch the car. When you want to shift to second, slap the shifter diagonally towards the right front corner of the car. If it's working properly, you will go into second and stop. Release the lever and it springs into position for the next shift. When you want third, again slap diagonally towards the front right corner of the car. The shifter should stop in third gear.
Old Jul 6, 2008 | 07:42 AM
Scotty B's Avatar
OK, thanks Joe, I hadn't thought about the diagonal pressure part...I will go out and do some, uh, research, later on today!
Old Jul 6, 2008 | 09:43 AM
Sounds like fun research. Of course, missing a gear or going into neutral would make me cringe if I was really getting into the secondaries.
Old Sep 9, 2024 | 02:35 PM
Shredder's Avatar
That's why, if you've seen under the top plate, the shift guide plate should look like a zig zag.
Old Sep 9, 2024 | 02:56 PM
Look at the date on your post, now look at the date on the last post, now back to your post, now back to the last post. Sadly, your posts aren't like mine, but they COULD be, if you stopped using lady scented body wash and switched to Old Spice, they could even smell like they were written by me. Look down, back up, where are you? You're on a thread that predates most of the members on this forum with its last reply. Look at your keyboard, now back at the screen; your epic thread necroing has been made hilarious by my parody of an Old Spice ad. Anything is possible when you look at the date of the last post and consider not replying if it's old. I'm on a horse.
Old Sep 9, 2024 | 03:59 PM
tru-blue 442's Avatar
Old School Olds
Spoiler
Old Sep 10, 2024 | 04:35 AM
BlueCalais79's Avatar
Aye, but this was a good refresher course for my practicing for next year's National's racing event with my 79 H/O. I had a heck of a time with my shifter this year in my 94 Supreme, but then again I'm making up yet another excuse for my shoddy performance that day.
Old Sep 10, 2024 | 04:46 AM
Shredder's Avatar
if you’re actually that bored (and boring) maybe you could get a second job writing comedy material for Bobcat Goldthwaite who’s just as unfunny as you…
Old Sep 10, 2024 | 04:57 AM
69HO43's Avatar
Whatever you do, don't yank the shifter all the way back and THINK you're on the notched side when you're not, stomp the gas to show off to your friends still in the parking lot, slap the shifter and end up in reverse. Car takes a nose dive in a hurry.
Right after I got my first 71 442 with the dual gate, I figured it was easy enough to figure out. But coming from a 69 4-speed and a 69 with the auto console before that, these funky new-to-me dual-gates was a learning curve. Lucky for me it didn't kill the transmission, but that was a huge lesson learned. I sheepishly put the car back in drive, and putted on down the road and went home in embarrassment. Always know where your shifter is.
puck4higgs
37
Mar 12, 2023 06:58 PM
pav8427
Jul 6, 2016 08:49 AM
cwracer
Apr 12, 2013 10:40 AM
hunter
Aug 15, 2012 02:08 PM
ELECMAN
Oct 19, 2009 06:32 PM
