Overfilled transmission
Old September 7th, 2015, 02:13 PM
harpelt's Avatar
Angry Overfilled transmission
Accidentally overfilled my Jetaway today. Any ideas aside from completely draining by removing the oil pan cover and replacing the gasket?
harpelt is offline
Old September 7th, 2015, 02:43 PM
lemoldsnut's Avatar
Most parts houses carry a syphone tool for this issue. It looks kind of like a grease gun and has a hose you put in the fill tube and pull the handle to draw out the fluid.
We have all been there.
lemoldsnut is offline
Old September 7th, 2015, 02:59 PM
X2, don't drive it if its way overfilled.
oldcutlass is online now
Old September 7th, 2015, 03:46 PM
X3.
Less than $20 for an oil sucker to stick down there and pull the extra out.
You need one anyway, because you can also use them to push oil into transmissions and differentials where you don't have the clearance to pour oil into them.
MDchanic is offline
Old September 7th, 2015, 04:49 PM
jaunty75's Avatar
Originally Posted by lemoldsnut
syphone
Siphon.
If he googles "syphone," he'll get nowhere fast as there is no such word. Google, which usually saves people from misspelled search terms, doesn't help in this case as it diverts you to "syphon," which is Apple/Mac software.
jaunty75 is offline
Old September 7th, 2015, 05:00 PM
Except that it's not even a siphon.
A siphon is started with suction, then continues to flow because of gravity and molecular adhesion.
The device in question is simply a suction device.
MDchanic is offline
Old September 7th, 2015, 05:06 PM
Tedd Thompson's Avatar
I've heard it called a Rose gun but a google search doesn't bring up anything like what we are talking about....Tedd
Tedd Thompson is offline
Old September 7th, 2015, 05:32 PM
344879M363895
70-442-W30's Avatar
Amazon.com: OTC (2359) Oil Suction Gun: Automotive Amazon.com: OTC (2359) Oil Suction Gun: Automotive
Last edited by 70-442-W30; September 8th, 2015 at 07:43 AM. Reason: Google link was dead
70-442-W30 is offline
Old September 7th, 2015, 06:18 PM
Old School Olds
tru-blue 442's Avatar
I always just cracked the bottom line at the radiator and put a pan underneath. Crank it it up until you think you've enough out, tighten and check.
tru-blue 442 is online now
Old September 7th, 2015, 06:57 PM
Octania's Avatar
You smart guys think you are so smart
maybe because you are?
Octania is offline
Old September 8th, 2015, 06:58 AM
^^^ DING DING DING. We have a winner.
joe_padavano is offline
Old September 8th, 2015, 07:56 AM
344879M363895
70-442-W30's Avatar
See my updated link above. If you don't have one, eventually you'll run into a case where you could use it. Cheap insurance against things like a brake fluid reservoir overfill.
Old September 8th, 2015, 08:17 AM
Old School Olds
Done that too, and with power steering. Just use an old terry cloth towel
to suck it up and toss it. If there's a way, a po boy will find it.
Old September 8th, 2015, 08:36 AM
hookem horns's Avatar
Originally got one for the boat but handy for other uses too.
Amazon.com: Powerbuilt (647570) Oil/Fluid Extractor - 6.3 Quart Capacity: Automotive Amazon.com: Powerbuilt (647570) Oil/Fluid Extractor - 6.3 Quart Capacity: Automotive
hookem horns is offline
Old September 8th, 2015, 08:38 AM
344879M363895
70-442-W30's Avatar
Hey, you ain't po until you've used a butter knife for a screwdriver. Been there, done that.
Pewter442
March 27th, 2015 07:06 AM
<ezra>
April 8th, 2010 08:25 AM
paul in san diego
January 15th, 2007 08:01 PM
phantom.10
December 10th, 2006 06:39 AM
Quick Reply: Overfilled transmission
