flushing transmission
Old November 10th, 2010, 08:29 AM
new user
bigwillystyle's Avatar
I had my TH-400 rebuilt, and I was wandering if anybody knows how to flush the ATF from the cooling lines. the lines go into the radiator then back to the tranny. Can I just put the air hose up to the line and all the fluid will blow out. Any help is appreciated.
thanks
bigwillystyle
bigwillystyle is offline
Old November 10th, 2010, 08:35 AM
Joe C's Avatar
You can buy transmission cooler flush in a can at NAAP or other good parts stores Hook up to cooler lines. The can is pressurized and will flush out old fluid. I have used this before and works well.
Joe C is offline
Old November 10th, 2010, 09:35 AM
X2. The aerosol can looks like this. You screw the hose fitting to one of the cooler lines from the transmission end and the flushed material comes out the other one. Be sure to use a section of hose to direct the outlet into a catch can. I use compressed air afterwards to get all the flush solution out.
joe_padavano is offline
Old November 11th, 2010, 12:47 PM
new user
thanks for the the help.......I just used compressed air to blow the old fluid out
Oldsragger
January 25th, 2015 04:07 PM
jeclin
December 2nd, 2012 10:20 AM
Finn5033
December 2nd, 2012 09:57 AM
ChefDeadpool
April 2nd, 2011 09:24 PM
paul in san diego
January 15th, 2007 08:01 PM
Quick Reply: flushing transmission
