fitting leak
Old Mar 25, 2009 | 06:10 AM
miho35o's Avatar
fitting leak
i noticed that a small fitting on the drivers side of my TH400 transmission is leaking. it has a hose coming out of it that runs toward the engine. Any idea what this fitting does and what fixing the leak involves?
Old Mar 30, 2009 | 04:52 AM
scrappie's Avatar
Are you sure it is on the drivers side? Is there a wire,hose or metal tube connected to it?
Old Mar 30, 2009 | 06:24 AM
Eric Anderson's Avatar
It took me a while to figure out that the "hose" you refer to is actually the speedometer cable. Follow it to the other end and you'll find it actually passes through the firewall (unless you have cruise control, in which case it will run to a transducer on the inner fender panel). There are two O-ring seals here, one between the housing and the trans case and one internal to the housing that seals the speedo drive gear. Both are easy to replace.
There were two threads on this question, Joe P answered it in the other. Had me scratching my head when I first read it too.
miho35o
Ninety-Eight
May 7, 2009 06:50 AM
Oldsguy
Sep 15, 2008 11:08 AM
bjtstarfire
Jul 26, 2008 08:41 AM
68Toro
Apr 4, 2008 06:04 PM
Olds Nut
Sep 18, 2007 07:10 AM
