edelbrock 1406 and 200r4
That's exactly what you need to do in order to clear that manifold. i have the exact same setup (except mine is a 1405). I had to bend the throttle tab at about 45 degrees
I went to the junkyard and bought a bracket off an 80's M4MC quadrajet for 5 bucks, it fit right on the back and works well.
yeah but where would i hook up the tranny tv cable to? dont i need to add a bracket to the carb to attach the tv cable? do i need this piece
I could probably grab a picture of my setup. But what i did was add a 1'' open spacer from MR Gasket underneath the carb. Cost around 20$ . I torqued it down and the air cleaner still clears the hood.
