Dual Gate Shift Cable
I have a '68 Cutlass that has a '68 Olds dual gate shifter. I need to replace the cable. Is there a special shift cable or certain length that I need to get? Will any Turbo 400 shift cable work?
Thanks, Mike
Thanks, Mike
It has to be a Dual Gate cable as it is a different length than the regular shifter cable.
It is available from various Olds resto places: Year One, Fusick, The Pats Place, OPGI, etc.
Here's a couple of links. The first one says it's a new GM cable and the second says it's a repro.
https://www.yearone.com/Product/1964...lass-442/8387n
http://www.opgi.com/cutlass/C240877/
I've checked out some of those web sites. The original '68 shifter came with a 53" (?) cable. Most places are advertising 30"+ cables. There are also GTO His/Hers sifter cables that are cheaper that are out there. Is there a required length? Is my 53" cable really the original one?
dylsexic typist perhaps, meant 35" ??
SO, the trans didn't move....
the shifter might be oh maybe 8-10" farther back if it's a dual gate.
23" more cable puts the shifter in the back seat unless you route a lot of extra cable in a loop or something.
Let's hear the experienced DG gurus explain the need for and use/ routing of a 53" cable.
Dale Von Krosigk
October 1st, 2013 01:54 PM
ah64pilot
May 29th, 2012 03:04 AM
