Driveshaft length Q
Driveshaft length Q
Going from a TH-350 to a 200R4 with an 8.5 rear is all the same, as far as drive shaft length goes. Would a 10 inch Olds rear change the drive shaft length with said 200R4 or is it the same?
TIA.
C.J.
TIA.
C.J.
The lenght of the turbo 350 and the 200r4 is pretty close, I think the 200r4 is about 7/8 longer.
The mount is in a different spot. Nothing a little drilling in you existing crossmember can't handle.
The yoke is different.
You'll need to convert the 200r4 to vacuum controled over computer controled. TCI just came out with a kit for that. It's $90 but IDK if you need to buy the extra vacuum valve for $30. Look in GM transmissions, under misc
This kit just came out in Janurary
http://www.tciauto.com/Default.aspx?...okieSupport=1#
The 200-4R uses the same driveshaft yoke as the TH350. Only the TH400 and the M22 Muncie have the larger yoke.
I have no idea what a "10 inch Olds rear" is.
texasred
Drivetrain/Differentials
April 27th, 2012 07:28 PM
