Driveshaft length?
Old Feb 9, 2012 | 03:11 AM
matviar's Avatar
Driveshaft length?
Hello. I have a 1970 Cutlass supreme with original 350 engine and tranny. I am replacing this with 455 engine and 400 turbo. Can I use my existing driveshaft or is it to long or too short for this swap? Any input would be appreciated. Rick
Old Feb 9, 2012 | 06:53 AM
Nope, you have 3 options. You can modify your existing driveshaft, have a new one fabricated or locate one for your application. I chose the fabrication route as mine was a 2 piece with the rubber insert. I inserted the T400 yoke into the trans all the way, pulled it out 3/4 of an inch and measured from the center of the ujoint on the yoke to the flat area at the rear differential (center to center). I called the local driveshaft guys and had a steel one fab'd new for about $220 assembled and balanced with new ujoints.
Old Feb 9, 2012 | 07:33 AM
Run to Rund's Avatar
1" rather than 3/4" is considered the best by Mark Williams who builds race shafts. They recommend up to 1.25". 3/4" could be too tight in some circumstances.
Old Feb 9, 2012 | 07:57 AM
The T400 yoke is really short! My guy's at the driveshaft shop recommended 3/4", it worked on mine with no issues!!
Old Feb 10, 2012 | 02:36 AM
matviar's Avatar
driveshasft length
So, is there any difference between a 350 turbo yolk and a 400 turbo yolk? I think I would have my existing driveshaft shortened, This may be the easiest, least expensive way.
Old Feb 10, 2012 | 03:15 AM
Some yolks are yellower, some are runny, all have plenty of cholesterol.
As for yokes, the TH350 yoke is smaller than the TH400 yoke.
Old Feb 10, 2012 | 06:50 AM
Originally Posted by mdchanic
some yolks are yellower, some are runny, all have plenty of cholesterol.
As for yokes, the th350 yoke is smaller than the th400 yoke.
- eric
x2 - lol!!!!
Old Feb 10, 2012 | 11:11 AM
You will also need to change your forward and intermediate e-brake cables. The TH400 requires the crossmember to move rearward and the cables hang off the crossmember. The TH400 cables are different as a result.
Old Feb 10, 2012 | 05:50 PM
matviar's Avatar
Sorry, I meant yoke. Anyway, will a yoke from another GM A body car with 400 turbo work? Are they the same as Olds?
Old Feb 10, 2012 | 08:03 PM
matviar's Avatar
Thanks Joe, I didnt even consider the e brake cables. CHA-CHING! more parts needed!
Old Feb 11, 2012 | 07:19 AM
You may not have to change your ebrake cables if you shorten the hook that attatches to the crossmember and then adjust your cable tighter. I installed a 1 inch hook in place of the stock one and it worked fine!
garys 68
Drivetrain/Differentials
Jun 20, 2012 06:41 AM
texasred
Apr 27, 2012 07:28 PM
texasred
Mar 14, 2011 07:42 AM
4-Speed
May 22, 2010 06:47 PM
ctrain22
Sep 8, 2009 12:15 AM
