Driveshaft length Q
Old Mar 12, 2011 | 01:31 AM
texasred's Avatar
Tom Servo's Stunt Double
Driveshaft length Q
Going from a TH-350 to a 200R4 with an 8.5 rear is all the same, as far as drive shaft length goes. Would a 10 inch Olds rear change the drive shaft length with said 200R4 or is it the same?
TIA.
C.J.
Old Mar 12, 2011 | 09:05 AM
Redog's Avatar
The lenght of the turbo 350 and the 200r4 is pretty close, I think the 200r4 is about 7/8 longer.
The mount is in a different spot. Nothing a little drilling in you existing crossmember can't handle.
The yoke is different.
You'll need to convert the 200r4 to vacuum controled over computer controled. TCI just came out with a kit for that. It's $90 but IDK if you need to buy the extra vacuum valve for $30. Look in GM transmissions, under misc
This kit just came out in Janurary
http://www.tciauto.com/Default.aspx?...okieSupport=1#
Old Mar 14, 2011 | 07:42 AM
TIA.
C.J.
Actually, the mount is in the TH400 location. And Olds built from 1967-on should already have the mounting holes for this location. If you have a 1967-72 car, be aware that the e-brake cables need to change to the TH400 cables since they hang off the crossmember and relocating the crossmember changes the front and intermediate cable lengths.
The 200-4R uses the same driveshaft yoke as the TH350. Only the TH400 and the M22 Muncie have the larger yoke.
I have no idea what a "10 inch Olds rear" is.
garys 68
Drivetrain/Differentials
Jun 20, 2012 06:41 AM
texasred
Apr 27, 2012 07:28 PM
matviar
Feb 11, 2012 07:19 AM
4-Speed
May 22, 2010 06:47 PM
ctrain22
Sep 8, 2009 12:15 AM
