Change vac switch Setting on 200-4R Transmission
Old May 16th, 2024, 04:47 PM
Tuffnut's Avatar
I would like to adjust the vacuum switch from superior on my 200-4R transmission so that it will lock up the torque convertor a bit earlier. Currently Set for 13”w/c. The convertor gets busy around 48-52 mph. Which way would I slightly adjust the screw? The switch has a range from 6”-22” w/c
TIA
Jeff
Tuffnut is offline
Old May 16th, 2024, 06:03 PM
nicks1966's Avatar
nicks1966 is offline
Old May 16th, 2024, 06:25 PM
Tuffnut's Avatar
I get the part about the adjustment, I just don’t know which way to turn it, less “w/c makes the torque converter come in earlier or later or more “w/c ??
I’m thinking if I want it to lock up earlier, I use the adjustment to have it lock up with more vacuum than what it is set at now ?
Tuffnut is offline
nracobraguy
October 2nd, 2021 03:23 PM
glord
August 7th, 2021 07:24 PM
steverw
August 21st, 2017 08:41 AM
Flye
May 4th, 2013 06:22 AM
mugzilla
Drivetrain/Differentials
November 19th, 2012 05:30 PM
Quick Reply: Change vac switch Setting on 200-4R Transmission
