76 Cutlass park lock system bushing
Old Aug 2, 2020 | 06:43 AM
Inline's Avatar
Seems like this item has gone MIA. Before ill fabricate something up, id rather by the correct part, if its available. Problem is, i dont actually even know that in what name i should search it? Assembly manual simply states " bushing". Any leads? Picture to clear the question. Item number 11.
Old Aug 2, 2020 | 08:22 AM
It’s available thru dorman, the Help section at the parts stores, plus countless aftermarket vendors. That bushing was used on pretty much every GM car and truck, column or console shift. You shouldn’t trouble finding one somewhere
Old Aug 2, 2020 | 09:31 AM
Inline's Avatar
Good to know its available.
Im still at miss how should i search it. Ive tried countless of different search words, but they seem to show up only some wire sleeves, rubber bushings etc.
Old Aug 2, 2020 | 10:00 AM
Search for "backdrive linkage bushing". Here's one source.
Old Aug 2, 2020 | 10:06 AM
Jouni, I think this is what you're looking for? Looks like the white bushing in the picture? The sides aren't square, they're tapered
Hardware, Cross Shaft to Frame Bracket, 1969-72 A-Body Column Shift, Back Drive
Old Aug 2, 2020 | 11:48 AM
Inline's Avatar
Many thanks!
matt69olds
Oct 13, 2020 08:22 AM
salami
Oct 13, 2018 11:53 AM
leroycjr
Mar 25, 2013 01:16 PM
Mike77
Mar 4, 2009 06:49 AM
New'n72
Aug 26, 2008 07:46 AM
