71 Cutlass S Transmission suggestions
Old Mar 19, 2017 | 08:01 PM
AK71CutlassS's Avatar
Looking to do a 350 to 455 swap this summer. I have 3.73 gears. The 455 will be around 500HP and 550-600 on the torque. I do have a TH400 that can be rebuilt. I will be 50/50 HWY AND STREET. what's my options? With the least amount of mods to car?
Old Mar 20, 2017 | 06:14 AM
The least amount of mods would be to get the T350 beefed up dramatically if that's whats currently in the car. The best option is to rebuild and beef up the T400. This will require the addition of a kickdown switch, modifying or replacing drive shaft, moving the trans xmember back and some ebrake cable changes.
Old Mar 20, 2017 | 06:15 AM
As long as the TH400 has a BOP bell pattern that would be an excellent choice. No need to hunt for a transmission when you already have one.
Old Mar 20, 2017 | 02:20 PM
Yeah i was thinking about overdrive but not sure yet. Yes the TH400 is BOP. I will get some quotes from local shops on rebuild prices.
Old Mar 20, 2017 | 11:36 PM
Should I get it built for later down the road adding the gear venders OD?
Old Mar 21, 2017 | 05:18 AM
A Gear Vendors unit is quite pricey. You would spend much more on the Gear Vendors unit than you would on a rebuild. That being said, I've only heard good things about Gear Vendors.
MudEye
Oct 14, 2016 05:12 AM
sjv328
Sep 9, 2015 07:40 PM
deejai35
Sep 3, 2012 07:53 PM
cosmo_dog
Paint
Apr 27, 2012 06:47 AM
cgjon
Jun 26, 2006 06:19 PM
