700R4 in '62 Starfire
Old Apr 22, 2009 | 01:21 PM
64starfire's Avatar
Here's a couple of pics a gentleman sent me on the install of this 700r4 in his starfire. Looks like a very tight fit. This was a modified bellhousing by Dave Smith Engineering, not a bolt in kit.
Old Apr 22, 2009 | 01:25 PM
64starfire's Avatar
Bolt in kits
The bolt in kits will require cutting the tunnel. That wasn't an option I wanted on my car since it's already been painted, etc. And I really don't have much sheetmetal skills to do it right too.
Old Jun 9, 2009 | 12:07 PM
KQQLCAT's Avatar
Are you telling me that this swap did NOT need tunnel enlarging?
Old Jun 9, 2009 | 12:18 PM
64starfire's Avatar
most likely
these pictures are from a trans that has had the bellhousing cut down....and it's a tight fit. Now add or (visually push back) 6" or so more of an unmodified tunnel.
Something that was brought to my attention in discussion once was with the body of the trans that tight in the tunnel doesn't allow for much airflow for cooling i.e. the case is made of aluminium. So either way, it's recommended that the tunnel get redone.
Old Jun 9, 2009 | 03:22 PM
Oldskeeper's Avatar
In 63 they (being GM) changed the angle of the drive train lowering the tunnel and kept it that way for 64 as well. So fitting a updated tranny in a 64 starfire will be even closer,you should measure the tunnel section width and hieght before moving forward.There are many 62 starfire guys on here that can measure their tunnels and check it against your tunnel.I would hate to see you go to all that modification only to have to chop the floor.
Just a thought.
Steve
Old Jun 9, 2009 | 06:48 PM
64starfire's Avatar
my plans
I'm going to tip the back of the engine down, install the whole setup, then lift up and go from there. I already know I'm going to have to cut and weld. I may go tunnel shopping at the local pick n pull. I saw a tunnel in a 73 continental that looked pretty tempting. Luckily the neighbor lady is moving out and letting me use her garage. It begins tomorrow.
Anyone want a slim jim trans?
Old Jun 10, 2009 | 06:51 AM
d2_willys's Avatar
That looks tight! I would think you could take a sledge hammer and get more clearance without having to graft in a new tunnel. I take it that the bellhousing was chopped down to fit the integral bellhousing of the 394.
Wonder if a 2004r transmission would be any better as far as clearance?
64starfire
29
Dec 5, 2018 09:08 PM
bob9822
Jun 18, 2015 02:16 PM
long64
Apr 30, 2015 07:05 AM
1962oldsguy
May 5, 2013 06:53 PM
64starfire
Apr 22, 2009 01:00 PM
