400 turbo id
Old Oct 24, 2017 | 05:18 PM
jarcher442's Avatar
400 turbo id
got this 400 turbo in a 67 442 that I just bought thinking it was the original switch pitch because of the 2 wires but in pulling the plug there was only 1 contact. Ok not a deal breaker, but the tag on the passenger side reads 79-AE 21422 I have spent hours on the internet trying to find what this trans came out of. No AE designatin shows up for any of the divisions. It is the standard BOP case. I,m assuming the year is 1979. After they changed the designation to 3L80 was the divisions changed? Any clue would be helpful.
Old Oct 24, 2017 | 07:06 PM
oldsmobiledave's Avatar
79 AE trans.
It is from 1979. It is not from any Buick nor is it from a Firebird.
That leaves 1979 GMC truck with diesel 5.7
1979 Olds 88-98 or full size Pontiac.
Good luck with narrowing it down.
Old Oct 25, 2017 | 06:32 AM
AE is a Cadillac trans. Caddys also use the BOP bolt pattern. This may actually be from a Seville with the fuel injected Olds 350.
Old Oct 25, 2017 | 07:24 AM
AE = Cadilac
Good catch. Totally forgot about the Cadillac interchange.
Old Oct 25, 2017 | 08:12 AM
As an FYI, the first letter of the TH400 two letter code USUALLY tells you the division (yes, there are some exceptions, like the OW transmissions used in Buick Gran Sports).
A = Cadillac (and also AM General for H1 Hummers)
B = Buick
C = Chevrolet/GMC
E = Volvo truck
F = Chevy/GMC trucks
H - Holden
J = Jeep
O = Oldsmobile
P = Pontiac
R = Rolls Royce (also Revcon motor home)
Z = Jaguar
??? = Ferrari
Old Oct 25, 2017 | 04:24 PM
jarcher442's Avatar
Wow got alot more info in a lot less time. I knew about Cadillac but totally forgot about the Seville with the Olds F.I. Okay if A is Cadillac then I guess E would narrow it down further say maybe Seville which would make sense with the short tail shaft. The Seville was basically a Nova. I was going to have it checked out while the engine was out anyhow so I guess I'll tell my tranny guy "make sure it's strong enough to handle between 350 and 400 hp." If they have to put more clutches in nows the time to do it then it can be made to whatever is needed to handle the engine. So just out of curiosity where was the info found designating Cadillac as A. I did find AM which was AM General. Thanks a bunch for the info guys.
Old Oct 25, 2017 | 05:25 PM
Cadillacforums.com and http://www.tpocr.com/cadillactc.html
Old Jul 18, 2021 | 06:04 PM
foxlovescars's Avatar
jarcher442:
I had EXACTLY the same question as you asked back in 2017. The transmission in my 1970 442 has "79 AE 44515 and I couldn't find any information anywhere on the internet until I came across your post. By the way, did you ever determine which Cadillac model your transmission came from?
Thanks,
Frank in Floroida
Old Jul 19, 2021 | 04:26 PM
jarcher442's Avatar
Yeh 1979 Cadillac Seville with the 350 Olds Engine
Old Jul 19, 2021 | 07:35 PM
Thanks. Isn't the internet wonderful? I wonder how many more Oldsmobile owners have 1979 TH400 transmissions from Cadillac Sevilles?
Frank
Old Sep 8, 2024 | 08:45 AM
Redhawk77's Avatar
Th400
Hi Joe,
having a tough time deciding my transmission. I recently bought a 1966 (supposed 442) Fremont, Ca car. Would anyone have any experience with transmission I’d tag AA-69 59190. Thank you in advance
Chuck
Old Sep 8, 2024 | 05:04 PM
Originally Posted by Redhawk77
Hi Joe,
Chuck
That trans is from a 1969 Cadillac, used in every RWD model except the Model 75 limousine. It will be a long tail or possibly the Caddy-only extra long tail trans.
Old Sep 8, 2024 | 05:49 PM
Redhawk77's Avatar
Joe, thank you for taking the time to respond to my question. I see you’re a busy guy on this site thanks again. 👍
Old Sep 8, 2024 | 06:17 PM
dragline's Avatar
AMC also used the TH400
Old Sep 8, 2024 | 06:22 PM
Redhawk77's Avatar
Thanks Dragline, after reading all the comments etc the site has been greatly helpful
Old Sep 8, 2024 | 06:30 PM
So did Rolls-Royce. What's your point?
Old Sep 9, 2024 | 12:33 PM
HydraMatic's Avatar
These are Fun Facts.
Another Fun Fact: the Dopplemayr "Sunnyside Double" ski lift at Mad River Glen ski area in Vermont utilizes a T.H. 400 transmission as part of its backup drive.
Next time that I'm over at MRG I'll take a photograph of the drive system and post it here.
https://www.newenglandskihistory.com...ift.php?id=133
oldsmobilejim
Aug 9, 2020 06:56 AM
Oldsmaniac
Jul 15, 2019 08:48 AM
rand5204
Mar 10, 2019 02:24 PM
Peewee
Sep 18, 2011 04:19 PM
therobski
Sep 26, 2010 08:31 AM
