What is this? Overdrive on a Turbo 400?
Old Jul 11, 2019 | 02:54 PM
Oldsmaniac's Avatar
Someone selling a 70 442 in bad condition and pictures this as the trans....
Old Jul 11, 2019 | 03:56 PM
Is that a transfer case mount as in a older Chevy 4x4 with a Turbo 400?
Old Jul 11, 2019 | 03:58 PM
CRUZN 66's Avatar
Olds Fever
That was my thought when I saw the photo...
Old Jul 11, 2019 | 03:59 PM
Oldsmaniac's Avatar
Not familiar but since you said it I would say yes.
Old Jul 11, 2019 | 06:15 PM
Heck, it's a Chevy trans. Look at the bellhousing.
Old Jul 11, 2019 | 06:27 PM
cherokeepeople's Avatar
and beings the modulator points to the back and it has a kickdown cable it is a turbo 350.
Old Jul 11, 2019 | 06:42 PM
The four bolt tailhousing pattern (as opposed to six) and square pan with the notched corner back up that observation.
Old Jul 13, 2019 | 06:48 PM
Schurkey's Avatar
Yup. Chevy-case TH350 intended for 4X4 transfer case.
Old Jul 14, 2019 | 10:09 AM
zeeke's Avatar
Not sure what it would look like but there was a company called Eagle Overdrive bake in the 90's that bolted on the back of the tail shaft. The other company that I know of is Gear Vendors. It looks to small to be any type of transfer case.
Old Jul 14, 2019 | 10:17 AM
Schurkey's Avatar
It's not a transfer case. It's the bigass cast-iron adapter that the transfer case bolts to.
Old Jul 14, 2019 | 02:19 PM
Oldsmaniac's Avatar
I missed the Chevy bolt pattern, from the side and a quick glance I was thinking BOPCad trans.
Old Jul 14, 2019 | 07:15 PM
my 82 diesel suburban had a doug nash overdrive.doug nash was bought by gear vendors.
Old Jul 14, 2019 | 07:50 PM
steverw's Avatar
Thats not even close to the size of my Gear vendors, and looks nothing like that end of it.
Im voting transfer case.
Steve
Old Jul 15, 2019 | 06:56 AM
^^^THIS! It is simply the adapter that mates the transfer case to the trans. It is NOT an overdrive. It is NOT a transfer case. It is just an adapter casting. And yeah, I realize the ones in these photos are not exactly the same. There are about a bazillion different transfer case adapters, depending on the actual transfer case and application.
Old Jul 15, 2019 | 08:48 AM
Joe is correct, really, the only difference between a 4x4 and a 4x2 trans is, if it's done right, the case itself. If you do the transfer case right, it's a direct bolt on, but sometimes you need an adapter.
Now, the legendary All Makes Combined AMC did use an overdrive that bolted on the same way the transfer case did, and they may have been the same transmission. A transfer case, after all, is only an engageable chain drive, and a gearing reduction.
Dec 9, 2018 02:03 PM
Pacecar
Jan 15, 2012 01:56 PM
Peewee
Sep 18, 2011 04:19 PM
therobski
Sep 26, 2010 08:31 AM
turnpike_cruiser
Jun 25, 2010 12:31 PM
