4 spd conv. parts
Old Apr 9, 2013 | 05:11 AM
scrappie's Avatar
4 spd conv. parts
I know this topic has come up before and I searched old threads but could not find a list of parts needed to do a factory auto to 4 spd conversion on a 71 442.
Here are the obvious things I know of besides drilling crank and adding a bearing. If anyone could add to list feel free.
Bell housing/bolts
flywheel/pressure plate/bolts
throwout bearing
clutch fork
Z-bar
engine mount?
trans
trans linkage
shifter
floor hump
pedal assembly
trans mount
Do I need a std steering column?
Do I need a new crossmember or do I just move the auto?
Do I need a new drive shaft
What about reverse lights?
neutral safety switch?
Speedometer cable?
Any little things that anybody can add? (wires, jumpers, clips etc...)
Old Apr 9, 2013 | 05:54 AM
dc2x4drvr's Avatar
You need: z-bar frame mt., and stud, MT neutral safety switch, move your crossmember, MT trans driveshaft will be required.
Costpenn just did a conversion, search his thread, Good Luck
Old Apr 10, 2013 | 07:57 AM
Type 4spd conversion into search. Here, I'll save you that trouble:
https://classicoldsmobile.com/forums...onversion.html
https://classicoldsmobile.com/forums...eed-howto.html
Old Apr 10, 2013 | 08:18 AM
allyolds68's Avatar
My442 posted this years ago on ROP. I know I've posted it here but can't find it and didn't see it in Joe's search either:
4-speed transmission - GM rebuilt
Floor hump - GM used or repro
Console for 4 speed - Convert an auto console with aftermarket parts
Muncie compatible driveshaft - GM rebuilt or aftermarket
Bell housing - GM Used
Bell housing inspection cover - Repro
Shifter and correct ball - GM Used
Shifter linkage - GM Used
Shifter to transmission bracket - GM - Used
Flywheel - GM Used or Aftermarket
Pedal Assembly and pads - GM Used for pedals, Repro pads
Neutral Safety switch - GM Used
Z-bar - GM Used
Z-bar to clutch fork rod - GM Used or Aftermarket
Z-bar frame bracket - Repro
Back-up light switch - GM used or Repro from M+H Electrical
Clutch fork - GM Used
Clutch pedal to z-bar rod - Repro
Speedometer cable - Aftermarket
Engine ball stud - Repro
Clutch pedal to z-bar rod boot & retaining ring - Boot is repro, ring is used GM
Shifter boot & retaining ring - Boot 1s repro, ring is used GM
Steering column lower support with hole for clutch pedal to z-bar rod - Used GM
Pressure plate, clutch disc, throw out bearing, pressure plate bolts, flywheel bolts - Aftermarket
Reverse lockout rods and bracket - Repro
Battery Cable - Repro fro American Autowire
Battery cable tube - Used GM
Firewall boot - Repro
You will also need to have a 4 speed crank that is drilled for a pilot bearing, or drill an automatic crank for a conversion bearing. I bought my conversion bearing from Supercars Unlimited.
The wiring is simple for the clutch switch and the back up lights.
The console harness from an automatic car can be used in the manual trans console.
There are 2 push in sheet metal nuts that are used on the base of the steering column to hold the back up light switch. My auto column did not have them.
Part Numbers from v8buick.com
68" Speedo Cable - 88959477 For 68-72 manual shift cars
Clips for shift rods - 12338114 Also used on the reverse rods too
Z bar and pedal bushing - 406172 Upper bushing and pedal bushing
Wave Washers - 9428369 Used to take out play in the linkage
Lock out rod bushing (upper) - 1394293 On the steering column
Bushing, reverse linkage (on frame) - 1377083 On the "L" shaped rod
GM has discontinued the rubber bushings on the shift linkage. Theses are being reproduced.
Old Apr 10, 2013 | 09:33 AM
scrappie's Avatar
Thanks a ton!
arcee1951
May 13, 2014 08:47 AM
507OLDS
Jun 26, 2013 09:21 AM
2blu442
Mar 24, 2013 09:47 AM
Prophe'c
Jan 24, 2011 01:37 AM
Prophe'c
Jan 23, 2011 03:24 PM
