convert 2 spd wiper to 3 spd on 66 cutlass
Hi, all. In have a 66 Cutlass with a 2 speed wiper, and the washer doesn't work. What all does a person need to to, to switch this to a 3 speed wiper? I believe that I have a 3 speed, out of a 67, and have the switch also. Has anyone done this? Thanks.
Sorry, but no you don't (unless you are counting "off" as one of the three speeds). Olds only offered single speed and two speed wipers in these cars. You need to figure out what you have. The wipers interchange between 66 and 67, so long as the switch matches the wiper (single speed vs. two speed).
Thanks, Joe. I checked yesterday, and both switches are 2 speed. The rear connections are different, but both have 3 pegs coming out the rear, so they should interchange, correct? I believe that I have a round wiper motor/setup from a 67, and my 66 has the small square type. Is there any advantage in the round, and would it bolt right in? I haven't really looked at it, since I am still fighting the fuel gauge problem.
oldspackrat
Mar 12, 2015 06:34 PM
vistacruiser1971
Nov 9, 2013 01:19 PM
2blu442
Mar 24, 2013 09:47 AM
