200R4 w.o.d VS 400R4 w.o.d
Old July 18th, 2013 | 12:09 PM
Olds1971's Avatar
I had a v6 car that now has a olds 350 in it. The rear end gear is stock 3.8 v6 gears which Im bumping up. I want a trans for power and streetable gas mileage with higher gears and is why it has to have Over drive. Which out of the 200r4 and 400r4 is the best to use for this?
Old July 18th, 2013 | 01:07 PM
What car are you talking about?
Old July 18th, 2013 | 02:11 PM
Olds1971's Avatar
Its a 1983 four dr cutlass with a 1972 olds 350 in it
Old July 18th, 2013 | 03:18 PM
1970-W30's Avatar
The 200-4R would be closer to a bolt in. The 400r4, I think you mean the 700-4r, would require a Chevy to BOP adaptor plate....
Old July 18th, 2013 | 05:21 PM
Redog's Avatar
Yeah really have no idea what you are talking about when you say 400R4. There is no such thing. There is 200R4, 700R4, 4L60e, and 4L80e.
200r4 is your best bet. Straight bolt on to an Olds motor and in 72 the 350 was putting out a bit lower torque, so in stock forum, you should be good.
You should buy a convertor lock up kit. You'll need it to lock the tranny in overdrive when you are cruising.
It might be in your best interest to swap the rear axle to an 8.5 instead of spending any money on that 7.5. You may get lucky and find a posi out of a 442 or GN in the local junkyards
Old July 19th, 2013 | 10:35 AM
As the others said, a 200 R4 would be a direct bolt in. You probably don't have to worry about upgrading any internal parts in the transmission if you keep your 350 stock.
Old July 19th, 2013 | 11:53 AM
Just to clarify, the names according to GM are 200-4R and 700R4. Go figure why they used a different convention.
Old July 19th, 2013 | 01:43 PM
Olds1971's Avatar
Yes that 400 was a typo I didnt catch. Im just looking for something better than 350 turbo when I put 3.73s on with a differwnt rear end
Old July 19th, 2013 | 03:25 PM
The overdrive would be handy when you swap to 3.73 gears. Although the TH 350 is a great transmission.
Old July 19th, 2013 | 05:07 PM
Be aware that your V6 car probably came with a TH200C. The 200-4R requires a different crossmember - though if you are converting to dual exhaust you'll be getting one anyway. Also, your 83's frame may not have the proper reinforcement for the 200-4R crossmember. If not, you'll need to get one of these:
It's called a "frame extension kit" and you can get them from Summit, Jegs, etc.
agtw31
April 10th, 2011 09:29 PM
skryla
March 2nd, 2011 09:01 AM
agtw31
August 8th, 2010 04:12 PM
ScottMHoffman
April 13th, 2009 07:22 PM
1971olds350
March 24th, 2009 08:34 PM
