1979 HO w30. Will this fit
Old Jun 22, 2025 | 09:23 AM
leftlaneonly's Avatar
Hi folks
I have a 1974 Oldsmobile 350 engine I am adding a Buick 1977 TH350 transmission. Ordered torque converter for a 1974 olds 350. Picture is the specs from torque converter. Will this all play nice. Planing on install next week.
also what is a ring gear that does not come with the torque converter. Do I need a new one or can I use the one on the car now.
thanks for any help.
Old Jun 22, 2025 | 11:03 AM
Some engine families have the starter ring gear as part of the converter. GM is not one of them. If the stall speed is close to what the factory had, and the converter is made correctly it should work fine.
Old Jun 22, 2025 | 11:15 AM
Would a torque converter for a Oldsmobile th350 also fit into a Buick or Pontiac th350 of similar years
or are there more surprises
Old Jun 22, 2025 | 02:05 PM
Yes, ASSUMING this is not a TH350C with the lockup converter. Since the TH350C didn't come out until the 1979 model year, that should not be a problem if your trans really is from the 1977 model year. The second character of the VIN derivative stamp will prove the model year.
Old Jun 22, 2025 | 06:06 PM
37C105587
Old Jun 22, 2025 | 06:41 PM
His data sheet says 1397 RPM stall. I have no idea if that is close to factory or not, but it’s way less than I would use. 1800 RPM would be my minimum, but I’m performance oriented.
Old Jun 23, 2025 | 03:45 PM
My mistake on the converter sheet here is the correct one I ordered sorry for the confusion
Thanks fun71
Old Jun 24, 2025 | 06:25 AM
37C105587
37Cxxxxxx is Oldsmobile Division (3) 1977 model year (7) South Gate, CA assembly plant (C).
Old Jun 25, 2025 | 05:30 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Thanks fun71
I find the factory converter flashes around 1600 rpm, makes a lazy launch with ypur factory 2.73 gears. As said a 2000 stall will increase launch a noticeable amount. Sounds like nothing is stock in the driveline, make the 79 H/O more fun.
Old Jun 25, 2025 | 01:26 PM
All parts collected and in the hands of my mechanic install Monday.
The mechanic is very familiar with this install and has done many. Hope all goes well.
Old Jun 25, 2025 | 02:09 PM
78Cutlass4Speed's Avatar
Dave,
Hopefully all goes well and you'll be up and running again soon.
Old Jun 25, 2025 | 07:12 PM
Same here. I would think a stall speed of 1400 would be pretty sluggish.
Old Jun 26, 2025 | 12:12 PM
I did go with the 1800 the first data sheet was the wrong one I added the correct one above your post 🙃
Old Jun 30, 2025 | 02:55 PM
Thanks to all for your valuable knowledge and answering all my questions.
the install went well the transmission is shifting smoothly I could not be happier with the results.
leftlaneonly
Hurst/Olds
Jun 8, 2025 10:57 AM
JLawrence
Mar 8, 2025 09:34 AM
Stevec
Jan 15, 2015 11:44 AM
jerseyjoe
Jul 1, 2013 06:50 PM
montvaleplace
Apr 8, 2011 01:52 PM
