1967 442 Hurst shifter
Old Feb 5, 2022 | 03:41 PM
Bills67's Avatar
I looked in my service manual at how to remove shifter arm and it says to use a feeler gauge to release spring, but it does not say what size and I tried all different size's with know luck! does anyone know the trick on how this works?
Old Feb 5, 2022 | 04:29 PM
RandyS's Avatar
Try the other side of the arm.
Old Feb 5, 2022 | 06:25 PM
Bills67's Avatar
what should I feel when I slide it in?( keep it clean) ha ha! Do I need some one to hold the tranny down when I pull up?
Old Feb 5, 2022 | 08:02 PM
edzolz's Avatar
You will probably need someone to hold the tranny down. I have had problem removing the stick with the trans in the car, out and on the ground will be a lot harder. Be sure you are sliding the feeler guage in the correct side of the handle. A little lubricant will help too.
Old Feb 5, 2022 | 09:42 PM
hurst68olds's Avatar
there is a sheet metal spring that locks the lever in place -
your feeler gauge is on the correct side - just make sure it is centered/wide enough to get both corners
Old Feb 6, 2022 | 10:19 AM
Bills67's Avatar
thanks for pics and the info, I was trying to remove it on my bench by my self so I will have my son-in-law help me hold it down to night.
Old Feb 6, 2022 | 06:44 PM
Bills67's Avatar
with a little help I got her out! thanks for info!
Andy
Apr 6, 2021 02:41 PM
allyolds68
Feb 9, 2020 08:43 AM
dejavu442
Hurst/Olds
Sep 17, 2017 05:40 PM
nelsontj
Aug 22, 2013 09:55 PM
Propaneking
Nov 13, 2012 05:37 PM
