1964 Rotomatic
Old Jan 28, 2026 | 12:06 PM
Steve76's Avatar
1964 Rotomatic
Just rebuilt a 394 engine and reinstalled it in the car. Transmission now shifts from 1st to 3rd by-passing 2nd. Any idea why?
Old Jan 28, 2026 | 01:12 PM
Did you adjust the throttle valve linkage on your 4GC carburetor per the factory service manual and use the recreated OE tool? If not, your transmission won't shift right.
20+ years ago I rebuilt the Slim Jim Rotohydramatic in my 64:98. I never set the throttle valve correctly. I even tried to go to an Edelbrock carburetor for a time. I finally sold my 64 after I got out of the Army. It slush box shifted for at least 10 years.
Old Jan 28, 2026 | 05:00 PM
Steve76's Avatar
Thanks. Since we put on a dual Quad set up it wasn't connected. We'll try and get it attached.
Old Jan 28, 2026 | 05:18 PM
rocketraider's Avatar
Oldsdruid
You still have to fabricate a throttle valve rod linkage that will work with the dual quad carburetion and then adjust it for correct transmission function. Turnbuckle style linkage rods will work.
Steve Westlake in Canada, @Oldskeeper here on CO, makes the TVR adjustment tool. www.jaswest.com
Old Jan 28, 2026 | 08:23 PM
Charlie Jones's Avatar
Phantom Phixer
You're going to have to do some real "engineering" on your dual carb linkage to get this transmission to shift properly.
What you're looking to do is to set the linkage so that the throttle arm on the transmission is all the way forward against the internal stop when the throttle is at "curb idle" ( choke off).
And it should come all the way back against the internal stop when the throttle is wide open. Good luck.
Old Jan 29, 2026 | 04:01 AM
Good luck setting the throttle valve linkage for your dual quad carburetors. FWIW, Oldsguy (my father) and I were never able to get that Edelbrock carburetor to shift right on my 64 98.
doc
Jan 11, 2026 09:32 AM
8691ecirpac
Oct 26, 2022 07:25 AM
jwmiles19
Nov 4, 2015 11:02 AM
blakes7
Jul 24, 2014 03:00 PM
