1956 flexplate problem
Old September 10th, 2012, 02:19 PM
59er's Avatar
Question 1956 flexplate problem
my wife has a 1656 98 holiday the flex plate is making a clugging sound. i took it to a mechanic and that is what we were told my problem is finding a flex plate for the car im really not sure what trans is in the car the car is all original. thanks if some one knows where i can start looking for one or where to start thanks
59er is offline
Old September 10th, 2012, 06:17 PM
CO53Super88's Avatar
I'm not familiar with the '56 but you might try Kanter Auto Products: www.kanter.com. You can call them for specific parts requests that may not be in their online catalog.
CO53Super88 is offline
Old September 10th, 2012, 08:03 PM
oldsmobum's Avatar
If you have a P on the column for PARK, you have the jetaway trans. If you Have no P on the column, and instead put in reverse to park it, you have the older hydramatic trans. Both were used in 56.
oldsmobum is offline
Old September 10th, 2012, 08:27 PM
59-59-59's Avatar
The '54 '55 and '56 automatics ('56 except Jetaway) used the same part number for the flywheel, so I assume the flex plate should be the same.
59-59-59 is offline
Old September 10th, 2012, 08:32 PM
59-59-59's Avatar
59-59-59 is offline
Old September 12th, 2012, 11:20 AM
59er's Avatar
Thanks for the responce to my flex plate it dosnt look like kanter auto on thetre website showes anything but i will call them there is a (p) on the colum for parking so i guess i have the jetway tranny so that a start thanks again.
59er is offline
Old September 13th, 2012, 11:08 AM
d2_willys's Avatar
Since you have a 56 98, you will have a Jetaway. The flexplate might be the same as 57-60. Have you tried Fatsco or Autotrans.com?
Reason why I said it might be same is because 57-60 flexplates will fit, but they may have weights on them, since the 57-60 Olds engines are externally balanced.
d2_willys is offline
Old September 13th, 2012, 03:50 PM
Tedd Thompson's Avatar
Also you might try Ross Racing, they should have what you are looking for if you run in to problems with Kanter. As stated above all 98 came with Jetaways....Tedd
Tedd Thompson is offline
indiandave
June 5th, 2013 04:38 PM
1FSTLS1
May 10th, 2008 09:40 AM
78cutlass
March 27th, 2008 04:46 AM
ilandtime
July 27th, 2007 04:53 AM
ilandtime
July 21st, 2007 09:56 PM
Quick Reply: 1956 flexplate problem
