flexplate problem
Old Jun 5, 2013 | 12:29 PM
indiandave's Avatar
flexplate problem
parted out 1981 buick riviera fwd,had a 307 olds moter,trying to find right flywheel so i can put it in rwd car,just got a olds 350 flywheel,it dont fit
Old Jun 5, 2013 | 02:22 PM
What does "it dont fit" mean, exactly? An Olds 350 flexplate will bolt to any 307 crank. The FWD 307s DID use a smaller diameter flexplate than any other Olds motor, but that doesn't affect how the flexplate bolts on. All Olds motors from 1968-1990 use the same crank flange bolt pattern. Are you SURE that flexplate is from an OLDS 350?
Old Jun 5, 2013 | 04:38 PM
indiandave's Avatar
flexplate problem
joe_padavano i didnt check for bolt pattern,you was right,it fits thank you very much
59er
Sep 13, 2012 03:50 PM
1FSTLS1
May 10, 2008 09:40 AM
78cutlass
Mar 27, 2008 04:46 AM
ilandtime
Jul 27, 2007 04:53 AM
ilandtime
Jul 21, 2007 09:56 PM
