1950 Hydromatic
The rod is called a TV or throttle valve rod, and besides allowing kickdown, it also regulates pressures internally to the transmission. The throttle valve pressure and governor pressure control shift points. (Throttle valve rod, does what a vacuum modulator does on some transmissions)
TECH9TWISTA
March 4th, 2007 04:44 PM
