whats the market like for 1966 toronado?
Old Sep 6, 2012 | 07:45 PM
nj_cutlass72's Avatar
I came across a 1966 toronado with a good running 455 engine, so instead of rebuilding a non running 455 engine from scratch which I also own , I may just swap the engine from the toronado with my 350 that is currently in my 72 cutlass.
So what does this have to do with my question? well the guy is selling the car as a whole. I dont really see many toronado's out there or interest for parts but that may be because im not looking in right places. If I was to remove the engine and sell the toronado as is, would there be interest? what if I was to make it a parts car, can I make some money? The body has rust and interior is OK, the pictures are not the greatest.
Ebay, craigs, I dont see much activity for toronado... if the steering wheel, seats, console, dash was from a 442, I would not ask this question so Im looking for your input based on your experience with Toronado's, how much would you estimate that I can make from selling the car without an engine or via parts -thanks.
Old Sep 7, 2012 | 03:06 PM
anyone? I guess this answers my question
Old Sep 7, 2012 | 03:18 PM
oldsguybry's Avatar
NOVICE car nut
There is interest , but not as much as the Cutlass , Supreme , 442 . I sold the dash out of the 68 Toro I use to own for a good price along with the rest of the interior parts . It didn't take long either , but that could of been coincidence .
Old Sep 7, 2012 | 03:38 PM
kartmaster's Avatar
Personally, I wouldn't take in a Toronado parts car... unless I needed a Toronado parts car. You'd part it out eventually, but it will take a while. The parts usually fetch a fair price though.
Old Sep 7, 2012 | 06:31 PM
what should i do? the engine runs but its ticking, is this a easy fix? take heads off replace valves or more serious in general?
im debating if i should buy it? its a toro engine with C heads, F block and a K intake....
Old Sep 7, 2012 | 07:09 PM
Scott Hamel's Avatar
ticking is prob just the valve train.. lifter thats not pumped up from the car sitting.. ( looks like its been ) does it have hi miles? i had a 403 olds years ago in a 76 firebird. and it was always noisy.. i replaced the rockers and bridges .. lifers.. i could not shut it up...lol
Old Sep 7, 2012 | 07:12 PM
i thought the 425 came in the 66? maybe someone swapped out the motor
Old Sep 7, 2012 | 07:37 PM
yea, in the 70s he swapped with a 455.
can you elaborate on the possible fixes for valve train?
Old Sep 7, 2012 | 07:46 PM
well you don't have to remove the heads to replace lifters or worn rocker arms it's a very cheap fix.. if your doing all the work. does the motor have good oil Psi? if it was not maintained there could be sludge in the motor.. did you bring it up to temp or was it just a cold start and then shut it off?
Old Sep 7, 2012 | 07:47 PM
Very true.
The engine described - F block, C heads, K intake - would be a '69-'69 Toro block (or non-Toro block with a Toro intake manifold), so if it's on a '66, it's not the original.
This could be good if a worn original motor was replaced with a low-mileage (or new) motor at some time in the past, but could be bad, as it indicates that the car has been messed with.
Old Sep 7, 2012 | 08:39 PM
Uncle Fray's Avatar
Ticky Ticky
If you have a couple of spare valve covers, cut a relief slot in the tops and open them up so a socket or screw driver can get to the rockers and put some down pressure on each one. The noisy one should change and with a VC gasket in place you can run the engine until it warms up WITHOUT running oil all over creation.
Old Sep 7, 2012 | 09:21 PM
the engine was replaced few years after 66 but then the car was parked indoors since the 80s, until 3 yrs ago it was kept outdoor.
Fray - interesting technique, i understand applying the pressure, if thats the fix, great! whats a VC gasket?
Old Sep 8, 2012 | 09:05 AM
D. Yaros's Avatar
whats a VC gasket?
I presume VC refers to valve cover gasket
Old Sep 8, 2012 | 05:54 PM
Well, it could mean Victoria Cross.
Old Sep 8, 2012 | 06:04 PM
starfire's Avatar
or Viet Cong.
Old Sep 8, 2012 | 06:20 PM
Originally Posted by starfire
or Viet Cong.
Of course. How is Victor these days, anyway? I've heard he traded his black PJs for an Italian suit.
guy.graziano
Paint
Jan 18, 2012 07:26 AM
tim72
Mar 25, 2009 10:28 AM
tim72
Body work
Feb 28, 2009 08:37 AM
citcapp
Jan 6, 2009 08:33 PM
Turbo Kyle
Jun 7, 2008 08:02 PM
