how do I test Vacuum Headlight Controller??
Old September 28th, 2019, 09:03 PM
tds
tds's Avatar
Help! My vacuum headlights will not open on my 1967 Toronado. I have checked all vacuum lines and they are good. How do I test the Headlight Controller and Headlight Check Valve? Any other ideas?
Thanks,
Tom
tds is offline
Old September 29th, 2019, 06:03 AM
With a vacuum pump or you can run temporary hose jumpers directly to them, and reverse the hoses back and forth from the intake with the engine running.
oldcutlass is offline
Old September 29th, 2019, 05:30 PM
tds
tds's Avatar
Eric,
I do not understand how to test the controller. Please provide more description on how to do it. I've attached photos if that will help
Thanks,
Tom
The controller
Underside of controller - looks like the plate covering the bottom will come off
tds is offline
Old October 13th, 2019, 08:17 PM
Toro X6's Avatar
Hey TDS - do you still need troubleshooting info for your '67 headlight system? When did it last work correctly, and what was changed since then? Sometimes that's the easiest way to diagnose. I'll post more specific info tomorrow. If you have answers to the questions before then, that might be helpful. Updates to follow.
Toro X6 is offline
Dr. J
July 24th, 2016 07:56 AM
tds
January 22nd, 2014 11:05 AM
elcaminodave
September 22nd, 2008 09:13 PM
Jaokiray
August 16th, 2008 06:32 PM
Birdwyre
July 22nd, 2006 09:59 AM
Quick Reply: how do I test Vacuum Headlight Controller??
