1970 Toro rear brake cable
Old February 15th, 2016, 05:30 AM
EightballZ's Avatar
hey guys,
any idea if the rear brake cables for 1966/67 may interchange with 1970?
already got the intermediate cable for my 1970 toro, but there are no aftermarket rear e-brake cables for 1970...inlinetube seems to have one for 1966/67
just need to confirm if the end fittings are the same. system looks to be the same as 1970 (long intermediate cable - equalizer below rear seats - rear cable connecting left and right drum brakes)
cheers
EightballZ is offline
Old February 15th, 2016, 08:57 AM
2blu442's Avatar
I've got a 1967 Toro parts car that I've recently cut up the body and removed from the frame. I can easily take measurements or photos of the rear emergency brake cable. What would help? Photo of where it attaches to the brake shoe? John
2blu442 is offline
Old February 15th, 2016, 01:16 PM
EightballZ's Avatar
hey john,
that would be awesome!
need to know overall length and need a picture from the part that connects to the e-brake lever. just to see if its the same type
thanks !!
Old February 15th, 2016, 06:06 PM
2blu442's Avatar
The way it connects to the brake shoe is the same as other cars of this vintage. Below is a photo of that. The length of cable from backing plate to backing plate is about 84 inches. Not precisely that length, as its hard to make the tape measure follow the shape of the cable. That also doesn't count what's in with the brake shoes, so that would likely add another 8-10 inches. If it becomes critical I can measure that for you. John
2blu442 is offline
Old February 15th, 2016, 08:38 PM
2blu442's Avatar
I got to thinking about it, and this measurement might be important. Plus or minus half an inch should be pretty close. This is from the backing plate to the support attached under the floorpan.
2blu442 is offline
Old February 16th, 2016, 12:01 PM
EightballZ's Avatar
Perfect...i got 82 inches so i guess that should work.
Thanks!!!
defiant1
February 4th, 2020 08:53 PM
cadillac kevin
September 1st, 2013 08:15 AM
dmberendsen
April 10th, 2013 03:18 PM
JohnNC
January 4th, 2012 01:39 AM
1970conv98
October 28th, 2010 08:10 PM
Quick Reply: 1970 Toro rear brake cable
